So I've purchased (against my better judement) a G2s "Pro".
Firmware loaded (RKMB_G2560) from the repository loaded after building and calibrtating ... then comes the setup for the Z probe..... Probe points are set to withing 2" of the 0,0 origin, and despite apparently completing the G29 probe, the grid ends thus:
19:11:52.678 : -4.68 -2.34 0.00 -0.58 -0.76 0.00
19:11:52.678 : -3.28 -2.09 -0.90 -0.30 -0.56 0.00
19:11:52.678 : 0.00 -1.84 -0.64 -0.03 -0.36 0.00
19:11:52.678 : -3.56 -2.24 -0.91 -0.34 -0.71 0.00
19:11:52.678 : -4.15 -2.96 -1.78 -1.30 -1.78 0.00
19:11:52.678 : 0.00 0.00 0.00 0.00 0.00 0.00
I don't trust the results as the values are far too high in places I know are very level.
The spider does not raise after probing, and just sits above the bed - commands to set z height to 0 result in the head raising to it's full height at slow feed rate, meaning I have to bring it back down to test the probe results - which "look" OK.
However, when a print is sent the nozzles slam into the bed......
Typical Geeetech firmware errors...
Re: Typical Geeetech firmware errors...
Hi, you can check your limit switch,
You can refer to this:http://www.geeetech.com/forum/viewtopic ... 13&t=17042
If you can, you can provide a specific video.
So that we can solve the problem better.
Thank you for providing this link. My limit switch is beyond limit I saw.William wrote: Fri Oct 18, 2019 9:16 am Hi, you can check your limit switch,
You can refer to this:viewtopic.php?f=13&t=17042 https://scrabblewordfinder.vip/
