Upgrade A10M to A10T
Ricky1966
Post by Ricky1966 »
Hi everybody. Someone knows how to upgrade A10M to A10T? I know the board is the same, GT2650 v 3, but must solder a connector up E2 driver's slot. Which is the hotend? Which is the firmware... Could you explain me more info?
Jarda3d
Re: Upgrade A10M to A10T
Post by Jarda3d »
The easiest way is to sell A10M and buy A10T. Or buy A10T and you will get two printers.
A10 Slic3r profile: here
Geeeko
Post by Geeeko »
I do not find the mixing extruder of the A10M pointless. It can be a lot of fun when it works as intended.
Currently at 400$, the A10T makes it quite expensive for 'just' a third extruder (and indeed a triple mixing chamber).
Jarda3d
Post by Jarda3d »
It is possible to add filament switch, aka Y-adapter. But you need 1 more extruder and 4P2T switch or do it electronically (driven by pushbutton on far axis end etc). 4x 1P2T Relay and pushbutton "brick" 2P2T on the far end of X axis is the simplest option. Driven by gcode....
Ricky1966
Post by Ricky1966 »
Ok. I've change prospettive. Do you think is possibile to "attach" Prusa MMU2 to GT2650 V3 board? So, I only change hotend (isn't stricktly needed) and work multicolor
Jarda3d
Post by Jarda3d »
Geee, add some "vertex" chamber into hotend mixing "cube" to make mixed colours uniform.
And agree, dual colour printer is only for 1% of tasks. It is time consuuming to prepare models and slicing.
Mixer is great, but 3 colours is not enough!
Cyan
magenta
yellow
white
black
transparent
support material
and at least 3 "effects"
metallic fill
wood fill
glow fill
temperature changes
