help firmware for A20M with the GT2560 board
LittleTrip
i cant seem to find the right firmware can someone help me with what one i need to download??? i own a A20m and had to replace the motherboard so i put in the GT2560 v3.0 everything on the printer works fine IF i use the USB and print with the computer but i cant use my screen on my printer cause all it shows is a blue screen so i believe its got the wrong firmware and i need the right one
Re: help firmware for A20M with the GT2560 board
Then the motherboard is normal,
You can try to reconnect the screen cable or check the screen wiring for damage.
LittleTrip
well someone said that they could of sent a board that had A10 firmware and all thats not the same is bed size and screen size so could that be right??
Hi, you can download the A20M firmware here: viewtopic.php?f=20&t=17046
Then refer to this update: viewtopic.php?f=20&t=17181
