Can't autohome
Mizuho
Can't autohome
Post by Mizuho »
I have just installed a new GT2560 V3 after I accidentally erased the bootloader from the original. I ordered from the Geeetech site and everything seems ok, the x, y and z axis can be moved in the menu, but when I autohome or try to print, the hotbed moves towards me and keeps trying even after it reaches the end of the rail.
Does anybody have any ideas?
Mizuho
Re: Can't autohome
Post by Mizuho »
Isn't it supposed to go that way? It's just going too far. If you move your Z axis say +1, does it go towards the back or front? Mine goes towards the back.
Mizuho
Re: Can't autohome
Post by Mizuho »
So it does, I thought Z was the hotbed...
Swapped Z and Y and it homed fine. Doh. The cable didn't look like it'd reach and my pictures I took before removing it weren't particularly helpful. I should've labeled them.
Much appreciated sir.
Mizuho
Re: Can't autohome
Post by Mizuho »
I don't really want to make a new thread for something so simple, but now when I use the dial to navigate the menu, I have to rotate 3 notches before it will select the next thing on the menu. Is there a setting to adjust this to 1?
