The Mac version doesn't work with Catalina !
An update please
Color mixing software for multi-mixing printer
Re: Color mixing software for multi-mixing printer
Hi, Can you open the color mix when you use this system?dtouton wrote: Fri Nov 15, 2019 10:21 pm The Mac version doesn't work with Catalina !
An update please
Can you describe your situation specifically?
Catalina needs 64 bits applications, I thing it's the problem
- Capture d’écran 2019-11-18 à 15.44.07.png (100.06 KiB) Viewed 31585 times
You need to run a chmod command in the terminal in order to be able to open the app.
