Recently i noticed that my X-Axis wasn't moving all the way over, so i tried moving it manually and found that moving it to its maximum value only made it go about a quarter of the way. If someone knows whats going on please tell me.
Hi, You can check if your x-axis limit switch is properly connected to the motherboard.
You can then connect the printer to your computer via USB and use the Repetier Host's manual control input M119 to check the status of the limit switch.
