A20m auto leveling
krumholzMax
A20m auto leveling
A20m auto leveling issues
just installed have error and printer head very high
can't print at all install 4 version for autoleveling somebody can check wiring??
- IMG_20191205_112058_4.jpg (308.45 KiB) Viewed 7072 times
- IMG_20191201_094800_2.jpg (365.71 KiB) Viewed 7072 times
- IMG_20191205_112107_1.jpg (450.88 KiB) Viewed 7072 times
Re: A20m auto leveling
Hi, after you install 3d touch, you need to calibrate it.
You can refer to this: https://www.youtube.com/watch?v=_RtsZDbR2po
Then you can in Repetier Host, enter the following commends and send them to test it one by one:
M280 P0 S10; pushes the pin down
M280 P0 S90; pulls the pin up
M280 P0 S120; Self test – keeps going until you do pin up / down or release alarm
M280 P0 S160; Release alarm
You can refer to this for specific operations: viewtopic.php?f=27&t=18371
krumholzMax
Repetier Host have no profile for A20m i cant connect i work with Cura have no problem with the connection it`s no not my 4 printer (cr20 - Chiron - Qidi 3 X-max)so i can`t do anything.. Video for a10m if my wiring its ok why i can`t push down the head- need calibration? How i do it in CMD
i flash my version so have connection
krumholzMax
I download profile for repiterhost it`s only for PLA not for printer still can`t connect to com6
Cura have profile i see its connected send g-code via CURA ?
Still, have no FILAMENT option in MENU
- Untitled2.png (229.75 KiB) Viewed 7059 times
- Untitled3.png (38.9 KiB) Viewed 7059 times
- Untitled1.png (460.32 KiB) Viewed 7059 times
- Untitled.png (154.7 KiB) Viewed 7059 times
Hi, If you cannot connect automatically,
you can try to install the driver manually:https://www.geeetech.com/forum/viewtopi ... RlcFtWdCG4
You can also test 3d touch by typing instructions in cura.
krumholzMax
I install the new driver 2019 - auto-leveling start measuring. i thought it`s ok. He connects to CURA 4.4 update the firmware. When it`s start to print its failed - print to high... A had enough. It was printing before installing sensor so i tired. I will try to remove the platform and install again. I just do video guide to Gearbest....
- IMG_20191206_111945_2.jpg (155.63 KiB) Viewed 7037 times
- IMG_20191206_112050_0.jpg (68.16 KiB) Viewed 7037 times
- 1234.png (37.09 KiB) Viewed 7037 times
- 123.png (45.73 KiB) Viewed 7037 times
krumholzMax
in Z changing to ? Its connected i just lower it
Hi, did you test 3d touch?
M280 P0 S90; pulls the pin-up
M280 P0 S120; Self-test – keeps going until you do pin up / down or release alarm
krumholzMax
I say Z jumpung i remove autoleveling what i do now?
krumholzMax
i raize and stabilize build plate but when i do home its go to low ..... its touch Z sensor i can't change to minus Z
- 00.jpg (296.16 KiB) Viewed 7033 times
