HI
I wanted to use the color mixer software for 3 exdruters.
Software does not work with 3
color mixer
Re: color mixer
Hi, You can use color mixer for color mixing,
Or use the on-screen color mixing ratio to set it.
You can refer to this about the use of color mixer: viewtopic.php?f=92&t=69600
Re: color mixer
HI
If I import the gcode then change color gradient and go to mixing the program closes
Re: color mixer
Hi,If this is the case, you may have problems with your slices or you can try running in administrator mode;
You can also download it again, maybe the wrong characters in the storage path cause this to happen.
Re: color mixer
Hi there
With Repetier host ...... works
With Simplify ............... does not work
