when plugging then x_m cable into the extruder socket I smelled burnt smoke and the printer stopped working. What should i do? Which piece should I exchange? Help me
Print model: A10T
Crash when connecting x_m cable into the socket of the extrusion
- image.jpg (456.3 KiB) Viewed 6900 times
Re: Crash when connecting x_m cable into the socket of the extrusion
If it can be opened, what is the situation on the motherboard,
Check if there are signs of burnout.
Use a multimeter to measure the continuity of the wires you connect.
I hope this can help you.
