Hi, Are you referring to printing being paused randomly?
Does this happen to all print models?
If you are using an SD card to print, you can try to replace the SD card.
GT2560 just freezes and connection is lost
Re: GT2560 just freezes and connection is lost
Hi William , i have the same problem when im using the USB port.William wrote: Wed Nov 27, 2019 11:39 am Hi, Are you referring to printing being paused randomly?
Hope they can give us a solution soon!
Random pauses,
You can try to update the firmware,
If this still happens,
There may be a problem with the chip on the motherboard.
Hi mate,William wrote: Mon Jan 06, 2020 9:20 amHi, If you use a USB to connect to a computer for printing,
Random pauses,
I update the firmware to Marlin.
Normally If i send to print a small object there is not problem, when they are bigger it stop always.
So you think the solution is to change the motherboard?
Thank you.
Can you provide your print paused gcode, I want to test it.
Are you using Windows for your Computer? If so, have you checked to be sure the operating system is not shutting down your USB ports to save power? This could cuase the symptoms you are describing.
3 days printing with usb without problems, today lost connection with pc and usb says no connection, I assume problems with save energy from windows, now printing from SD without problems, I will deactivate the option for deactivate usb and test it.
Best regards.
Best regards.
Please, support my collaboration, buy me a Kofi https://ko-fi.com/lachusmadeti THANKS!!
