Question about A20M fan placement
rikku
Post by rikku »
I'm new to 3D printing. Recently, I had a problem with the hotend so I replaced it. But I don't take care about the 2 fans placements. Since, my printer often pause printing without error message. I just have to select "Resume" to continue but it's a little bit annoying for long prints.
I suspect I mount the 2 fans in a wrong way. Actually, the 2 fans take the air from outside to the hotend.
Could you confirm the direction of the air flow ? (I wonder if left fan take air to the hotend and the right to outside, but not sure).
Sorry for my stupidity -_-!
Re: Question about A20M fan placement
:D Hi, The fans inside the hot end housing are on both sides of the hot end.
Is for cooling fans,
One left and right.
rikku
Post by rikku »
Thanks for answer.
My question is more about the direction of the air flow of each fans. Is it from inside the hotend to the outside or vice versa ?
I tried to draw my question, see files below :)
What is correct ?
:D Hi,it is 2.
Jarda3d
Post by Jarda3d »
No. 2???
On my A10M it was configuration No.1 from factory (2018/10 model). Warm flow is going to printed model.
So what is right in reallity?
A10 Slic3r profile: here
rikku
Post by rikku »
Jarda3d wrote: Sat Jan 04, 2020 10:30 pm No. 2???
I don't think the fans on the sides go to the model. It's the 3rd fan's role, the one with a duck to cold the print. Maybe I'm wrong ?
Jarda3d
Post by Jarda3d »
Maybe.
I am waiting to official Geee answer about fan direction...
chc
Post by chc »
I want to change the fans, in order to get something quieter.
Does someone has good links to quieter fans?
Power supply's Fan :
60*60*15 mm / 12 V / 0,2 A
MotherBoard's Fan
50*50*20 mm / 24V
Best regards,
Christophe
Jarda3d
Post by Jarda3d »
Look at my signature
Admin
Post by Admin »
oh, Jarda3d is right.
