HI all,
i tried to print this owl from thingiverse: https://www.thingiverse.com/thing:18271
it's about 15 cm tall but when the printer were at approx 13 cm it stops extruding so it continues to print movements but with no filament.
what could be the problem in your opinion?
A10M not ends print
Re: A10M not ends print
The nozzle temperature is around 200 and then manually push the consumables,
Check whether the nozzle is discharging.
If it is blocked, clean it up in time.
