Hello sorry my lenguage,im a italian guys.
I bought an a10t, but I don't know how to connect the 3d touch sensor wires.
I can't find a guide for the A10T on how to connect the sensor.
the printer without the sensor becomes crazy and does not calibrate, does not stop and pushes the extruder on the plate with the risk of breaking everything.
Help me please
3D touch A10T
Re: 3D touch A10T
After installation, you need to update the firmware to a firmware with 3d touch,
However, there are some problems with the firmware of 3d touch, which are being repaired.
Re: 3D touch A10T
I'm also interested in this. I bought my A10T along with a sensor to use so I didn't have to use the "paper" trick of leveling and have tried several ways to update the firmware with no luck. The official Geeetech firmware didn't even have an option for this as far as I could tell and after following Vert's directions and trying his firmware I had the same issue of the Z axis not stopping and causing non-stop movement into the print bed. I haven't even printed anything yet due to this. Any help would be great.
Re: 3D touch A10T
I have also a A10 and a 3D touch, how is the software debugging going?
Re: 3D touch A10T
Great Vert! Will you be posting it to the download section for the A10T when ready? I've very anxious to get things rolling.
