BLTouch on A30M
Maccron
BLTouch on A30M
Post by Maccron »
A30M with 3DTouch.
Re: BLTouch on A30M
Hi,The current firmware corresponds to 3d touch. You can try not using the built-in leveling, thanks for your feedback.
Maccron
Re: BLTouch on A30M
Post by Maccron »
A30M with 3DTouch.
Re: BLTouch on A30M
Hi,Are you referring to the z-axis bending? You can explain the situation to your sales.
TacoScientist
Re: BLTouch on A30M
Post by TacoScientist »
I am having very similar issues as to what you're having, I am using the regular A30 though. I also can get M280 P0 S120 working to start the self test FWIW. Using newest public firmware that is suppose to support 3D touch I can not get the auto leveling screen controls to work using the pull up or drop pin. I wonder if the official BL touch sensor is actually supported or just the 3d touch?
Here is my post on the issue: https://www.geeetech.com/forum/viewtopi ... 65&t=70016
Maccron
Re: BLTouch on A30M
Post by Maccron »
A30M with 3DTouch.
gio@dkonline.be
Re: BLTouch on A30M
Post by gio@dkonline.be »
BLtouch not supported i have tested, only 3Dtouch ( geeetech sell 3Dtouch and has locked all other brand ) and 3D touch is have many many bug with smartto A30 A30M A30T firmware. never give good value. no problem with proxy sensor.
proxy sensor work verry verry better. model
Ils - 12A3-4-Z/BX DC 6-36V
Maccron
Re: BLTouch on A30M
Post by Maccron »
I order one to test it.
A30M with 3DTouch.
Maccron
Re: BLTouch on A30M
Post by Maccron »
A30M with 3DTouch.
xengeist
Re: BLTouch on A30M
Post by xengeist »
I tried connecting 3DTouch and my wires are about 10mm-20mm too short. Here some pictures of how I have it rigged, can someone verify the wiring I had a difficult time finding the proper way to connect it. One diagram looked like the brown and black wires were on top. I noticed posting these pics that the extenders are crossed on the black and white and I already fixed that. I would prefer not to use the extenders Ideas are always accepted. :D
