About how to connect the 3d touch
Re: About how to connect the 3d touch
:D Hi, The specific insertion method is 3pin brown wire on, 2pin black wire on.
you can refer to this:
3d touch接线参考.png (140.09 KiB) Viewed 26702 times
lmcmulle
Post by lmcmulle »
orange on top and black on top is the working config
duglas
Post by duglas »
So, i can't make it work following all your discussion. could you please write down a step by step procedure on where connect the wires, with a picture (that will be one among all the others) and links on the procedures to update-setup the program of the 3d printer and make it work (calibration).
thanks
Geeetech A20T 3 mix 1
Chany
Post by Chany »
Bonjour,
Je viens d'acheter donc cette fameuse Geeetech A20T avec le 3D touch.
Ou se trouve le firmware avec le 3D touch pour cette imprimante. Je ne le trouve pas....
Merci
Hi, the firmware with 3d touch is still being tested.
It will be uploaded after the test.
Fredoooo
Post by Fredoooo »
Des news concernant le firmware 3d Touch pour la A20T??
Fredoooo wrote: Thu Mar 19, 2020 5:19 pm Des news concernant le firmware 3d Touch pour la A20T??
:D Hi,you can select the corresponding model to download on the download page of the official website.
You can refer to:viewtopic.php?f=20&t=70221
