My bed has stopped heating reliably and even errors out the printer if I try. I'm looking into replacements and fixes.
Aside from the official Geeetech parts, are there any other compatible beds I should consider as a potential upgrade or replacement?
Replacement Bed Options
Re: Replacement Bed Options
Hi,Are you referring to the fact that the bed itself cannot be heated?
Are you measuring thermistors on a hot bed?
If I set my bed to heat to 60C, it gets to about 57C and holds there until the thermal protection kicks in and shuts everything down. It will still *sometimes* get to temp but not reliably so. I assume it's a broken solder connection on the bottom of the bed but I haven't torn it down for full inspection yet.
At this point literally every time I've replaced, fixed or adjusted anything on this printer, something else has broken and so I just jump to looking at replacements rather than assume I can service anything and I know to expect it to be some degree of disaster.
Try manually heating it to 40c, then go to 60c.
The software has protection built in to prevent runaway heat and fire. You may just be getting a false scare signal. There is a process to calibrate the bed heating, that I have not tried. You could try moving the temp sensor and see it it changes the reading a little. The temp is measured by a probe pushed in a hole, if not well positioned, it can read air and make the temp lag slow. Apparently the calibration deals with this, but just reseating the sensor could press it against the aluminum.
https://www.youtube.com/watch?v=YpWCKNagjuI
For a better bed, I bought boro glass (boroscoptic?) and adheared it with spray mist adhesive for screen printing and use hairspray for adhesion.
If you can walk up to 40c to 60c, the heater is fine and the software is confused, which could be contact location.
I've gone back and run the M303 E-1 S60 which worked fine. It's possible in my tinkering I broke those settings so I'll cross my fingers and see what happens.
I don't exactly understand what's happened now - I an auto-tune the PID to any temp I please and it works fine.
Once tuned, the bed stalls out around 50-51 degrees until the protection kicks in again and shuts it down.
