* cura
1. After installing 3d touch ..
Mix value within cura start G code cannot be applied.
M163 The set mix value is not applied.
-It is applied by putting mix value in A20T lcd screen.
-If you change the A20T firmware to old (not bl touch), the mix value in cura is applied.
2. I want to increase the nozzle temperature after applying G29 (Bad Level Test).
M104 S200
G28
G29
M109 S200
(The G-code above is being used by Ender 5 3d print.)
* Please let me know the cura start g code again.
Re: After installing 3d touch ..
Hi, thanks for your feedback, and we will discuss and give you feedback.
Hi~
I want to know the cura start G code that can be mixed with 0.33 0.33 0.34.
I want to output the same STL file with various mix values.
Hi, you can try downloading color mixer on the official website
Import the cut model for color mixing.
