Geeetech Prusa i3 Aluminum - Board Sanguinololu Rev 1.3a - Firmware?
mbeach1116
Post by mbeach1116 »
Where and how do I update the firmware for this version ?Geeetech Prusa i3 Aluminum - Board Sanguinololu Rev 1.3a
Re: Geeetech Prusa i3 Aluminum - Board Sanguinololu Rev 1.3a - Firmware?
Hi, you can refer to this:viewtopic.php?f=20&t=17046
mbeach1116
William wrote: Tue Mar 24, 2020 10:52 am Hi, you can refer to this:viewtopic.php?f=20&t=17046
I saw this post but dont understand which to use, etc.
mbeach1116 wrote: Wed Mar 25, 2020 1:41 am
Hi, you need to choose to download according to your model and motherboard corresponding type,
Then upload it using Arduino.
mbeach1116
William wrote: Wed Mar 25, 2020 10:19 am
I understand that. How do I know which model and motherboard I have?
mbeach1116 wrote: Wed Mar 25, 2020 11:03 pm
Hi, your model is i3 aluminum
You need to download it from the corresponding firmware,
Motherboard, you can check your motherboard,
The corresponding model is written on it.
I hope this can help you.
mbeach1116
William wrote: Thu Mar 26, 2020 10:25 am
How do I know which to use? Here is the options from the link you provided above.
3) Firmware for Aluminum I3
For sanguinololu, you need to copy the folder named "sanguino" to the folder "hardware" of Arduino IDE.
The "sanguino" folder:
sanguino.zip
(209.25 KiB) Downloaded 3767 times
Download this file and unzip it and move it to the folder "hardware".
1 for sanguinololy.jpg (34.93 KiB) Viewed 320440 times
Then you can use the Arduino IDE 1.0.1 to upload the firmware as the link:
viewtopic ... 20&t=16433
For the old aluminum i3(with printed extruder bracket and gear), use the firmware below:
aluminum I3 Ramps 1.4
PI3_Ramps14固件.rar
(199.43 KiB) Downloaded 3849 times
aluminum I3 sanguinololu
PI3_Sanguinololu固件.rar
(229.44 KiB) Downloaded 4069 times
For the full aluminum I3, use the firmware here:
for the upgraded kit using lead screw
Plusa_I3_A_sanguinololu(for the upgraded kit using lead screw).zip
(242.47 KiB) Downloaded 3749 times
Prusa I3A 2560.zip
(281.17 KiB) Downloaded 5509 times
Plusa I3 A sanguinololu.zip
(242.28 KiB) Downloaded 5444 times
mbeach1116
Can you help? Please see message above.
mbeach1116 wrote: Wed Apr 01, 2020 10:32 am
you can download this:
and refer to this to update:viewtopic.php?f=20&t=16433
mbeach1116
William wrote: Wed Apr 01, 2020 12:00 pm
you can download this:CRFNI3Z}D$OY7K3XU`Y56}X.png
I believe I have updated it. Is there a way to confirm?
