Simplify3d profile with 3d touch?
handsome1987
Post by handsome1987 »
I have a geeetech prusa i3 pro b with a 3d touch.
Does anyone have a profile for it for simplify3d?
RBandeira
Re: Simplify3d profile with 3d touch?
Post by RBandeira »
I have the same question. I have a Prusa i3 Pro B with 3DTouch and I would like to set the best profile in Simplify3D.
If someone have answer it will be great.
Thaks.
RBandeira
SolomonShawn
Post by SolomonShawn »
Im a newbie to this .. and i have managed to assembele the printer my self with the help of a few vids on you tube .. and how .. I have plugged the printer on and plugged it in to the USB to the Mac, the lcd says card ok start test .. but when I have tried to use the nob tail nothing happens and when i press t it makes a strong noise .. I have tired un plugging the USB but it still says the same but doesn't do anything ..
One person said on facebook to download the stl convert it to gcode then to put it on the sd card then to the printer .. which I don't know what stl or code are or where to get them or anything at all really ..then another person said you don't have to if you have it plugged in by USB ....
Hi, If you want to print,
You need to import the model you want to print into the slicing software,
The general model is stl format,
After slicing, it is in gcode format, the printer can only recognize gcode format
You can connect the printer to the slicing software of the computer via USB to print,
You can also import gcode into an sd card for printing.
GamingPuggle
Post by GamingPuggle »
SolomonShawn wrote: Wed Apr 08, 2020 3:44 pm Im a newbie to this .. and i have managed to assembele the printer my self with the help of a few vids on you tube .. and how .. I have plugged the printer on and plugged it in to the USB to the Mac, the lcd says card ok start test .. but when I have tried to use the nob tail nothing happens and when i press t it makes a strong noise .. I have tired un plugging the USB but it still says the same but doesn't do anything ..
One person said on facebook to download the stl convert it to gcode then to put it on the sd card then to the printer .. which I don't know what stl or code are or where to get them or anything at all really ..then another person said you don't have to if you have it plugged in by USB .... prepaidcardstatus
Happy to help! Thanks for leaving a comment.
pinknemo13
Post by pinknemo13 »
William wrote: Wed Apr 08, 2020 4:03 pm Hi, If you want to print,
Thank you so much thanks for the reply! :)
KriKri854
Post by KriKri854 »
Does anyone hase the A30T profile for Simplify3D?
thanks
