Head Extruder Wire connection
cala
Post by cala »
I have buy a new extruder for my A20T. Do you have the connection schema with the board ?
I have try to reconnect like the preview one was connected, it heat but not working well.
The PLA is not pushing out correctly.
I'm pretty sure is my wire connection wrong.
Thanks in advance
Best regards
Re: Head Extruder Wire connection
Hi, you can view it according to the wiring diagram:
GT2560 V4.0主板接线图.jpg (617.34 KiB) Viewed 9467 times
cala
Post by cala »
Thanks. I think is not clear my message. My issue it's with the part 3 in 1 out hotend kit for A10T A20T (SKU:700-001-1265).
Sometimes the filament go out, sometimes not. The temperature seams OK : 215 °C for PLA. Filent 1 it's working but the others 2 color nothig is going out. the motor pushing the filament it's working.
I have buy a new one to replace the existing. My printer is new and can't do nothing with. When I have receive the printer, the model from the card have work fine. Now also the model it's not print correctly.
Best regards,
Calà Salvatore
Hi, Hot end installation,
You need to install the hot end into the heating cage,
For the transfer board part, you can refer to:
cala
Post by cala »
THANKS. SOLVED.
:D
