My printer don't print
Re: My printer don't print
Hi, Normal room temperature,
The thermistor temperature is around 80kΩ,
Whether the wiring at the hot end is loose?
Briciou62500
No the wiring is good
Briciou62500
There must be a false contact, on the heating bed, it is at -19 ° C then 17 ° C re -19 ° C then 17 ° C ...
Hi, are you referring to the temperature change of the hot bed?
Thermistor of the hot bed is at 80kΩ at normal temperature
Can you provide a question video?
Briciou62500
Between blue and green, the multimeter is on 200k ohm.
The value on the screen is 5.2
- IMG_20200330_194714.jpg (247.24 KiB) Viewed 19814 times
Briciou62500
Today my bed don't heating
Hi, your hotbed thermistor is broken,
you need change it.
you need change it.
Briciou62500
So, I just saw that it is more complicated than that, when the bed is plugged into the box (power supply, motherboard ...) I have 5.2 but when I unplug the cable, I have 122. The multimeter is still the 200k caliber.
Briciou62500
It is break or not ?
Hi, based on your test data
This is not normal.
This is not normal.
