how print only with 2nd extruder with cura
maverickk89
Post by maverickk89 »
hello,
I'm using Cura 4.6 and I would like to know how to print using only the second extruder, it's annoying change often the filament when I mainly use two colors....
I tried to disable first filament on the menu above the model but it seems to not work...
Re: how print only with 2nd extruder with cura
Hi, you can adjust the color mixing ratio on the screen 0: 100 is the second extruder work:
1. Select "Mixer", press the knob, turn the button to select "Mix: 0%; 100",
adjust the mixing ratio, and press the knob to confirm the setting.
2. To quickly switch the ratio between E0 and E1, select "Toggle mix" to switch.
maverickk89
ok but where could I found "mixer"? I cannot see it...
Hi,it is on the main menu.
maverickk89
is there away no set it directly on Cura? (preferring not using gcode manual customization)?
Hi,you can use color mixing software,refer to viewtopic.php?f=92&t=61760.
Hope to help you.
maverickk89
solved, it was just to right click to the element and decide with estruder has to print it...
in any case thank you :)
:D
