Issues on first print on solo mode
TaZOr
Post by TaZOr »
Hello All,
I'm new on the community and on 3D printing and I really need some help with my A20M.
I can't seem to print using Cura. The gcode included on the SD works like a charm, anything else just does not work.
I'm using Cura 4.6.1
My A20M is on version 1.1.8 downloaded on Geeetech site
I'm trying to print the Articulated Lizard V2 (https://www.thingiverse.com/thing:3509154)
Screenshot_2020-05-02 Articulated Lizard V2 (Dual-Extrusion Remix) by Polymathic.png
Screenshot_2020-05-02 Articulated Lizard V2 (Dual-Extrusion Remix) by Polymathic.png (952.87 KiB) Viewed 4120 times
My bed is leveled manually but should be OK since the Dog gcode printed perfectly. (I leveled the bed several times to be sure)
I used the profiles found on the thread https://www.geeetech.com/forum/viewtopic.php?t=62065 for A10M
I tried to slow down the speed to 40mm/s instead of 60.
Heated the bed more
Heated the PLA 200, 210, 215
Tried several profiles of PLA
Nothing seems to work...
Here is the result I get:
Heating the PLA to 215 has a better adhesion but not enough to keep printing.
Another issue I have is I am having a really hard time using both colors of the printer.
EDIT:
Sorry guys the problem is solved on thread: http://geeetech.com/forum/viewtopic.php?f=92&t=61760
My bad...
I set it manually on the printer and I can make it work but printing the Lizard in 2 color, I really don't know how to do it...
I tried selecting different PLA profiles to be sure both were going to be used.
I enabled the Dual Extrusion with the prime tower.
Thanks for your help
TaZ
TaZOr
Re: Issues on first print on solo mode
Post by TaZOr »
Problem solved!
I should have listened to the several tutorials on YouTube... 90% of the problems with newcomers is BED LEVELING!!!! :oops:
I used this design to check how my bed was: https://www.thingiverse.com/thing:4077747 (A simple X shape for dialing in the first layer)
The result:
After a new bed leveling taking into account the results:
https://www.thingiverse.com/thing:214260
Now everything is in place and working!
Some tweaks are still needed... But I'm printing!
https://www.thingiverse.com/thing:1692395
Thanks!
TaZ
:D
