LCD display problem
alexy34
Re: LCD display problem
Post by alexy34 »
LCD failed upgrade
LCD failed upgrade
LCD failed upgrade
alexy34
Post by alexy34 »
inside control box
LCD conection
LCD conection
back LCD
back LCD
control box
control box
alexy34
Post by alexy34 »
lcd connction
lcd connection
lcd connection
Hi, This is the corresponding UI file.
UI.rar
(1.02 MiB) Downloaded 345 times
After swiping the screen, be sure to dial out the SD card. Otherwise, it will automatically refresh the screen upon power on.
alexy34
Post by alexy34 »
Hi, i don't understand
Hi, you can download this UI file and update it.
and you need to remove the SD card after the update is complete.
alexy34
Post by alexy34 »
this one ?
the right UI ?
the right UI ?
alexy34
Post by alexy34 »
I update the UI first or the firmware.
is this the right update ?
firmware update.JPG (53.26 KiB) Viewed 6357 times
Hi,This firmware is incorrect.The following are the correct firmware and Ui files:
A30_V2.01.01 (1).rar
(1.23 MiB) Downloaded 329 times
Motherboard firmware: A30_M07_V0_01.bin (CRC32: 4E6ED0BA)
LCD screen firmware: A30_S02_V0_01.bin (CRC32: D65698E0)
1. First burn the motherboard firmware: use the "firmware_tool_V2.0" burning tool for burning, and it must be the firmware_tool tool of version V2.0 or later.
2. If the screen is still black, burn the screen firmware: use the "firmware_tool_V2.0" burning tool to burn.
3. If the screen is still black, refresh the UI: save the system in the UI file to the SD card, insert the Sd card into the card slot, the screen starts to refresh, the refresh is completed, and the Sd card is pulled out.
