problema
juanjose
problema
Post by juanjose »
Dear seller
I need help with the printer.
The printer is not printing ok, it is starting priting soft pieces (not stiked), they look cork.
I have clean the hoted and nozzle, also I have changed the Telflon-tube and I adjusted the extruders, and I could not fix it.
Could you please help me with this?
Thank you so much for your help
Kind Regards
Re: problema
Hi,sorry I didn't understand, can you provide pictures?
juanjose
Re: problema
Post by juanjose »
La pieza impresa parece buena pero con nada que la toca se rompe parece corcho
WhatsApp Image 2020-05-06 at 17.33.23.jpeg (86.18 KiB) Viewed 3703 times
WhatsApp Image 2020-05-06 at 17.33.23 (1).jpeg (57.66 KiB) Viewed 3703 times
WhatsApp Image 2020-05-06 at 17.33.22.jpeg (69.34 KiB) Viewed 3703 times
Re: problema
HI,it seems that some place is not set up when slicing. You can reset the slicing according to the manual.
