Display dark after update firmware A30
Hi together,
I have a problem with my A30 printer, after I wanted to update (with EasyPrint3D) the firmware the display is dark.
I tried all descripted things - but nothing happened. viewtopic.php?f=20&t=68694
In my Geeetech A30 there were no sd-card in the display, but I tried an other (1Gb) to get the firmware on the display.
But when ever I put the files on the sd-card an put it in the display-slot, after switching on and wait a while and switch off the bin-file and config.txt was deleted from the sd-card. And also the display is still dark.
Is there anybody who have a solutuion to get the display running? The Printer by it selve can used by EasyPrint3D, but that's not the way I want to use it...
hopefully I get soon a answer.
CaHaZo
CaHaZo
Re: Display dark after update firmware A30
Or is the screen blank?
If the screen is blank, you can try to update the UI.
You can refer to: http://geeetech.com/forum/viewtopic.php?f=65&t=60740
Make sure your SD card is inserted when updating the firmware.
the display shows nothing - like switched off.(...but the LED from LCD are on....)
I try also viewtopic.php?f=65&t=60740
But after doing this and check the sd-card again the bin-file and the config.txt are gone from the sd-card. They are deleted from display after switching on.
And when I try to use smatto_upgrador_1_2_for Win (select A30_M_LCD_V1_37.bin) is shows:
deceted LCD bin file!
Initializing Global Configuration...
Entering Normal Mode....
Start to Upgrade LCD...
Upgrading failed! Detail: Reach to max tried!
Also A30_V3 is not working....
So the result is still the same. It seems there is something wrong in the installed LCD-UI. Is there a possibility the delete the LCD-software direct on the LCD?
regards
CaHaZo
regards
CaHaZo
Hi, If this happens,You need to insert an external memory card.
I hope this can help you.
I try it - not working.
But now I hear 2 times a "beep" when switch on and also when smartoo wants to update the LCD.
Which software should be on the main-board? A30_VD_S_V1_58.bin?
and LCD A30_M_LCD_V1_37.bin?
Hi,You can download it using the firmware on the official website.
https://www.geeetech.com/download.html?download_id=38
Then follow this step to update.
About easyprint does not recommend using updated firmware,
There may be a problem.
I try now everything. Display still black.
I build this out. The name written on the board ist Smartto_LCD 3.2'' VER2.1 FRA.1.6mm 2019-09-05.
It looks different to the pictures in the Internet. Is this maybe the problem, that the LCD-Software did not work with this Display?
regards
CaHZo
regards
CaHZo
The first upload is A30_M07_V1_59,
Then insert the SD card when uploading A30_S01_V1_38?
If the screen still cannot be displayed after uploading correctly,
There may be a problem with the screen.
I have the same problem, but i've resolved the mother board and lcd firmware update , with VER2, but the lcd screen still dark.
if you want the solution let me know.
Regards
Regards
