Hi i recently purchased a 3d Touch sensor for my I3 Pro B with GT 2560 Rev A.
During the installation i stuck at this part:
Step1. Remove the Z max connector from the board and replace it with a 3Pin Straight Pin. You need to use soldering iron here.
I don't have any way to do it.
Is there's any other way to install the 3d touch without removing this connector??
Thank you.
						3d Touch GT 2560 Rev A
Re: 3d Touch GT 2560 Rev A
Hi,it can be adjusted down without removing it.
Hi, there's a guide to do that?
thank you
						thank you
Loosen the screw to move it down, then tighten it
