Z- Height
Scuttle130
Z- Height
Has anyone gotten the Z-Height to stabilize correctly? Every time i try to set it as 3 sheets of paper width, the filament doesn't extrude when the print starts. Occasionally i will get a weak print (one you can crush with your fingers). Most of the time i get nothing coming out of the extruder.
Scuttle130
Re: Z- Height
Here is a picture of my problem... is there a way to set the height? I searched the forum and found ways for other printers, but not the I3 Pro C.
Scuttle130
Re: Z- Height
The forum won't accept my jpgs.
Scuttle130
Re: Z- Height
It took a little testing but the G Code of G92 resets the X, Y, Z position. Gotta use capital letters. Example:
G92 X1.0 Y10.50 Z23.5
So this sets the software to the coordinate so you can move the extruder past what was a the "zero" location.
