From the description you presented, I can see one relation - communication is disturbed when the heaters are started.
snaptube vidmate word to pdf
Communication Timeout
oliverthom707
Re: Communication Timeout
Could this also explain why is cuts out after a while even when being able to print? The same thing occured when using an SD card, so it didn't seem like a communication issue at all. Could the power supply also cause the 'gibberish' text?
