I got my very first 3D printer and wanted to test it by printing the benchy. So I added the printer in cura via custom fff printer, entered the dimensions, filament size, heated bed etc. After putting in filament and leveling the bed I started the print and the printer started, but the nozzle wasn't nearly where I leveled it, but rather 2-3 mm above the plate. Obviously i canceled the print.
Did anyone have the same problem or know where this may come from? Could false settings in cura be the cause or did I fail at leveling the bed correctly? Or is it something I totally missed?
I researched on the internet and I saw you can set an z offset value in your starting gcode. Should I just try to find a value to lower the nozzle?
Thanks for your help!
Problem with Geeetech A30: Z Axis is 2-3mm above the bed at the start of the print
makerbiles6
Return to “Geeetech A30 Series”
Jump to
- Update Announcement/Product Release
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3/DIY Printer Series
- ↳ FAQ-Geeetech I3/DIY Printer series
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Configuration Profiles Sharing
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- ↳ Video about cleaning and replacing nozzles
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
