Problem with Geeetech A30: Z Axis is 2-3mm above the bed at the start of the print
makerbiles6
Post by makerbiles6 »
I got my very first 3D printer and wanted to test it by printing the benchy. So I added the printer in cura via custom fff printer, entered the dimensions, filament size, heated bed etc. After putting in filament and leveling the bed I started the print and the printer started, but the nozzle wasn't nearly where I leveled it, but rather 2-3 mm above the plate. Obviously i canceled the print.
Did anyone have the same problem or know where this may come from? Could false settings in cura be the cause or did I fail at leveling the bed correctly? Or is it something I totally missed?
I researched on the internet and I saw you can set an z offset value in your starting gcode. Should I just try to find a value to lower the nozzle?
Thanks for your help!
https://omegle.onl/ vshare
Re: Problem with Geeetech A30: Z Axis is 2-3mm above the bed at the start of the print
Hi, if you are not using 3Dtouch, it is recommended to re-level, you can adjust the height of the hot bed by the knob under the hot bed.
