The instructions for the 3d touch install stop at the part using andruino...
i dont understand if i edit the configuration.h on my printer or upload a new one?
im not even sure how to edit the configuration.h
these instructions kind of explain it but not sure? viewtopic.php?f=13&t=17181
has anyone got a written a detailed guide on how to use andruino to edit the configuration.h?
i dont want to wing it and be in a bigger mess.
in short i guess; how do i do this?
Step1.Open the firmware in Arduino IDE,find the following code in Configuration.h:
3d touch firmware instructions
Re: 3d touch firmware instructions
Hello, it is not recommended that you change the firmware settings yourself. You can directly download the already set firmware. Such as the link below.
viewtopic.php?f=20&t=17046
- firmwar i3 prob.jpg (41.39 KiB) Viewed 9217 times
Correct, if you don't know how to modify marlin (firmware) download the firmware from Geeetech and install.
Best regards.
Best regards.
Please, support my collaboration, buy me a Kofi https://ko-fi.com/lachusmadeti THANKS!!
ok so i did all this. got it updated tried a few different versions and the 3d touch is not responsive at all.
it starts up the pin goes up and down a few times goes red... then not responsive to any commands.
Sounds a defective probe, it´s strange that simptoms.
Best regards.
Best regards.
WilfredWise
This is really amazing. Great information about blog.William wrote: Thu Sep 10, 2020 3:54 pm Hello, it is not recommended that you change the firmware settings yourself. You can directly download the already set firmware. Such as the link below.![]()
viewtopic.php?f=20&t=17046/Tellpizzahut
