A10M Bed hitting the printers Y axis switch really hard.
loky
Post by loky »
When I auto bed level the bed. it dosen't level it like it should too it. 'Pls look at the video' https://youtu.be/XvewuFwzRoo
Przepka1985
Re: A10M Bed hitting the printers Y axis switch really hard.
Post by Przepka1985 »
:D :D easy 😊 I was got same issue with a10t. But it involves to edit config.h cause printer movements size y its -7 to 225 (than its not 230 like define in config.h)
You need to change x_bed_size 225
Y_bed_size 225
X_min -1 y_min -7
Upload and test it.
On verts marlin 2 bug fix you will get same issue.
Best regards
Pawel Rzepka
Przepka1985
apollos wrote: Tue Oct 20, 2020 5:48 pm Hi, thanks for the solution i will try it
You need to use non stock firmware.
I will prefer to use original but got couple of problem with code. And geeetech not rush with upgrades or release source code.
