Texture very bad at rear part of build
TonyEng
Post by TonyEng »
My Mecreator2 over a couple of years has printed may very wonderful prints wth very good quality but recently it gradually needed new bearings as the texture degraded so I changed the X and Y bearings. But now the front apprimately half of the build area produces a reasonable good print quality but the back part is very bad. Some layers are shifted back on the Y axis by upto about 1mm and some are ok, making it very rough. I have reduced the accelerations and jerks to a minimum and am printing with PLA at 50mm/sec with a travel of only 30mm/s. Have retraction of 5.0mm with -0.5mm restart.
Any ideas are welcome :)
Bad texture at rear.JPG (288.38 KiB) Viewed 29176 times
Re: Texture very bad at rear part of build
Hi,regarding the problem of layer shift, you can check the tightness of the belt; whether the bearing has the proper lubricant; whether the drive plate voltage is 0.8-1.2V.
TonyEng
Post by TonyEng »
Thanks William for your fast response and great suggestions.
I am assuming the voltage and lubricant are fine as the front half prints without layer shifting. The bed is 160mmx160mm - only the front 50-80mm works without layer shifting. I thought it might have been due to alignment of the belts but I have check and I think I have these very well aligned. The belts are very tight and held in tension by small clips that came with the print and I have added a belt tensioner holder I printed from Thingiverse.
Although I have been very careful when I take it apart and the rods all seem very straight - I have rolled them on a table and can't see light though at any time.
Regarding the blobs, I have a lot of retraction, but will increase this and if no improvement, I will try and change the feed.
regards
tony
camilasmith934
Post by camilasmith934 »
Get the very easiest & simple way to book your Flight Tickets at Delta Airlines Reservations, our customer service 24*7 available for customer support, you can easily book your flight tickets by visiting our website.
camilasmith934
Book your flight tickets at Allegiant Airlines Flight Reservations, we provide ultimate discount on flight tickets booking.
camilasmith934
<a href="https://clinkergram.com/blogs/5927/What ... >Allegiant Airlines Flight Reservations</a>
<a href="https://www.click4r.com/posts/g/2383816 ... >Allegiant Airlines Reservations</a>
<a href="https://www.smore.com/9vtka-pet-strateg ... >Allegiant Airlines Phone Number</a>
<a href="https://latamairlinesreservations.wordp ... >Allegiant Airlines Reservation Number</a>
<a href="https://justpaste.it/8yd13">Allegiant Airlines Booking Number</a>
<a href="https://www.linkedin.com/pulse/allegian ... >Allegiant Airlines Flight Reservations</a>
<a href="https://camilasmith934.tumblr.com/post/ ... >Allegiant Airlines Reservations</a>
<a href="https://www.reddit.com/user/camilasmith ... >Allegiant Airlines Phone Number</a>
<a href="https://rewardbloggers.com/blog/post/15 ... >Allegiant Airlines Reservation Number</a>
<a href="https://sites.google.com/view/allegiant ... >Allegiant Airlines Booking Number</a>
<a href="https://www.800customernumber.net/airli ... >Allegiant Airlines Booking Number</a>
<a href="https://www.eranewblog.com/travel/alleg ... >Allegiant Airlines Phone Number</a>
