Hi people, am glad that it works
https://vpnblackfriday.com/nl/
Geeetech e180 and tmc2208, tmc2209 motor driver
Re: Geeetech e180 and tmc2208, tmc2209 motor driver
I watched the related video previously and made the settings in the video with mks gen l. particularly sensorless homing is extraordinary. Be that as it may, we can not design tmc2209 in light of the fact that Geetech e180 doesn't uphold marlin. that is, we can't initiate highlights, for example, sensorless homing, miniature venturing. Under the momentum conditions, 16 miniature advances is set with jumpers under the engine driver. I got inconvenience free with a 0.750v extruder set. On the off chance that there is an issue, it tends to be expanded somewhat more. As you stated, more current might be required for the immediate drive extruder. I favored tmc2209 on the grounds that it made less commotion. my neighbors are more joyful at this moment. particularly in prints that proceed until the morning.
Hello
why do you set only 0.75 V ??? I measured on old drivers is around 0.95 - 1 V
Setting the vref value too high causes the drive and motor to overheat and be damaged. setting it too low will cause step skip. so setting it to the lowest value where it won't step will get the best performance. If your printer's axes are not properly adjusted and it is difficult to move, the value of 0.750 may remain low. It's okay to make 0.95 and 1v either
It's simple - different drivers have different Vref equations
ivacy vpn is offering the best black friday vpn deal. lifetime vpn for $60 Check it out
https://www.ivacy.com/vpn-deals/black-friday-vpn/
