Filament do not stick on the Super plate
dizais
Post by dizais »
Just fitted new Super plate, but work is coming off from the plate, do not stick. Coming of in the middle of work. Do I need to use glue or something else?
LC76
Re: Filament do not stick on the Super plate
Post by LC76 »
I just received my Super Plate in the mail today, and immediately fitted it to my A30T.
Although I was getting perfect ABS prints using the original mylar platform, as soon as I tried my first print on the Super Plate, it was instant disaster as the first layer didn't adhere at all, with the same slicer parameters.
I found an extremely simple kludge was to reduce the z-axis clearance by 0.015mm using the auto-leveler.
I normally print the first layer at 0.3mm. Changing my z-axis offset from -1.85mm to -2mm seems to have done the trick. I can now get a perfect ABS print done again.
