unknown LCD2004 display (Marlin)
hdv
Post by hdv »
Hi, I have an unknown LCD2004 display and controllboard.
I don't know what kind of type I should select under Marlin. I allready tried some without success.
Can anybody identify this board by the pictures?
thx
LCD2004 rückseite.jpg (921.63 KiB) Viewed 11396 times
LCD 2004 Vorderseite.jpg (678.39 KiB) Viewed 11396 times
hdv
Re: unknown LCD2004 display (Marlin)
Post by hdv »
OK, I found a similar problem here, so I ground off the noses of the connectors and put the cables in the bases front to back.
Then the display works as a normal LCD 2004 and also the controller works.
>>> I just recognised that it only works, if there is a I2C Interface connected to the dispaly. I wonder why - but ist works this way.
