No x axis movement
kendean
No x axis movement
Post by kendean »
Have built this and trying to setup from the lcd panel. First task is to level the bed using Auto Home.
z and y axis move ok but no movement on the x axis.
Swapped the x and y cables on the control board; now the x axis moves but nothing on the y axis.
Does this suggest a control board problem?
Also have a problem in that the bolt holding the x axis idler catches on the middle bolt holding the right side frame to the xz frame.
Thanks in advance
Re: No x axis movement
:D Hi, 1. The position of the motor port on the motherboard
The motor cannot run, and there may be a problem with the motor port on the motherboard;
2. About your x-axis idler screw,
Can you send specific pictures?
If it does not match properly,
It needs to be replaced.
JThomas
Post by JThomas »
Geeetech has an information about 3D printers with series. They are providing a setup of an axis movement. If you will check this lab report writing services then you can get admirable skill about the study. You can also get their control board problem system. They will provide an information series to you. Join them for more.
