Duplicator 5, Y and Z are flipped... causing the motors to keep turning.. even when reaching the end
monhe
Post by monhe »
I have a problem with my duplicator 5.
I just assembled then and now the Y and Z are flipped... causing the motors to keep turning.. even when reaching the end..
The X axis, it has a direction from left to right and when it reaches the end it stops and walks a little backwards (I think that is correct).
The Y Axis, moves from the back to the front but when reaches the end , the motor keep turning, i need to use the "emergency stop"
The Z axis moves Up to Down and didnt stop too, i need to use the emergency stop.
At the beginning, the Z and Y axes had the opposite direction, but I installed the "duplicator" firmware and changed the directions of both axes.
What can I do to correct this problem?
Thank you for the help,
Falk1993
Re: Duplicator 5, Y and Z are flipped... causing the motors to keep turning.. even when reaching the end
Post by Falk1993 »
I would say that is a great trick to succeed in your college study but you should not demand much from the life of security but assignment homework can be done with https://australianwritings.net/cheap-as ... australia/ online which is a easiest way to follow up for your pending homework to do anyway.
