Hi i am new to 3D printing but just got my first printer. I successfully printed a dog which turned out fine, now im trying a second print it starts off ok then after a few seconds it stops extruding the filament and i noticed the heat rapidly going down (I assume this is why it stops printing). The extruder still moves as if it's printing but the filament stops coming out. Any ideas as to what is causing the extruder to rapidly lose heat? I am completely new to this so any help is appreciated.
Thank you.
Linda
A10M Extruder Losing Heat During Print
Re: A10M Extruder Losing Heat During Print
Hello, it may be that there is a problem with your heating element. You can ask geeetech official for help. They now use the ticket to reply.
The following is the creation process.
- ticket process.rar
- (389.76 KiB) Downloaded 2777 times
Hi, I had a similar problem .. i fixed it by re-soldering the whole print head board as i had a number of dry joints.
i also recommend getting some heatsink to feed cabling through to protect them.
