problemi di stampa - estrusore
filo70
Post by filo70 »
Buongiorno,
abbiamo appena finito di assemblare la geeetech Prusa I 3 pro B.......
1- la stampante non viene riconosciuta dal computer tramite USB
2- l'estrusore non gira (immagino sia un problema di Firmware)...quando carico il file di stampa la stampante inizia il percorso di stampa ma non esce il filamento
3- se fosse quello non so come caricare il nuovo firmware
qualcuno mi può aiutare?
grazie ;) ;)
jonsag
Re: problemi di stampa - estrusore
Post by jonsag »
Firmware problem is not my first thought.
Connect the extruder to another driver (with no filament loaded) and run it by that drive instead.
If it runs, then there is a problem with the driver.
If not, I'm guessing it's some kind of connection problem.
/jon
NikoValvedia
Post by NikoValvedia »
Every adolescent necessities to have a remarkable relationship that will intrigue you and you can find an awe inspiring youngster dating who will give you incredible love. Youngsters who are keen will latinas mail order brides constantly have to banter with you and offer a perfect relationship. There is basically an opportunity to find a relationship and family for you.
