hi i have a i3 pro b printer but I have the impression that it prints too fast the layers do not stack i use easy print thanks you in advence (i thinck the problem are the speed byt not sure)
https://ibb.co/N1B13wp
https://ibb.co/2WZsQNG
https://ibb.co/3CQP7JR
My i3 pro b print not stack the layer
Re: My i3 pro b print not stack the layer
Following the advice given here, downgrading Keras did the trick for me without having to touch any other packages. Just do:Clarity wrote: Wed Jun 02, 2021 6:29 pm hi i have a i3 pro b printer but I have the impression that it prints too fast the layers do not stack i use easy print thanks you in advence (i thinck the problem are the speed byt not sure)
Code: Select all
pip install keras==2.3.0Myloweslife
