How to install MARLIN update?
Blue_Collar
Post by Blue_Collar »
I have the firmware update kit installed on windows. How do I update the Marlin version?
——————— last update 10-16-21
1). Geeetech i3 pro C with custom x axis, extruder carriage, Noctua fans, PIA magnetic build plate, 3d-touch, Marlin 2.x
2). Geeetech A20T with 3 in 1 out Geeetech extruder (diamond hot end failed), magnetic PIA build plate, dual gear extruder upgrades, Marlin 2.x
3+). Prusa Original MK3s x 2, Mini, MMU2s, Mosaic Palette 2s pro
—using PrusaSlicer, openSCAD
Admin
Re: How to install MARLIN update?
Post by Admin »
Hello, please refer to the video below:
https://www.youtube.com/watch?v=HFOvyX0slbs
Just check the updated part of its firmware.
Blue_Collar
Maybe I’m confused, but the linked video seems to be about the 3d-touch which I have already gotten working. I wish to update Marlin to 2.0 in hopes of having the menu selective color mixing function to be of some use. Current Marlin version is 1.1.8. How does one update Marlin?
Blue_Collar
Never mind... I figured it out. Now I’ve lost 3D Touch. Gone are the days when a company ships a usable product...
BreeOge
Post by BreeOge »
I have 2.0 marlin installed in my A20T with 3D touch if you need any help I can try.
BreeOge
Post by BreeOge »
Blue_Collar
Thank you so much! I’ve been very frustrated with the A20T, but it is good to know there is someone out there willing to help. I finally got Marlin to install after what seemed like a painfully long time. I have a diamond head on the A20T right now. I’ve got the “basics” to work, now it is a matter of “dailing in all the details. I’m using Prusa Slicer since I am most familiar with it. I’m trying to build a profile for the A20T from scratch... and I have the ugly prints to prove it. Any suggestions would be welcome.
Thank you for your willingness to help, I’m sure there will be more hurdles ahead.
BreeOge
Post by BreeOge »
If you don't have Marlin 2.0 installed yet, goto https://github.com/Vertabreak/Vert-Marl ... 0t-testing and Vert keeps an updated version just for A20T. His version has the 3d probe setup, and UBL Mesh. He has most of it dialed in, however you will still need to tweak it to your filament. One good way is if you can use Cura Ultimaker it has an addon that has calibration tools, you can do a temp tower and retraction tower with ease.
Blue_Collar
Thanks for the info! I’ll give it a try!
yoyof
Post by yoyof »
bonjour je n'arrive pas a passer a marlin 2 sur mon A20T j'ai toujours un message d'erreur lors de la verification quelqu'un a une solution je ne suis pas expert dans se domaine
Capture marlin.JPG (115.56 KiB) Viewed 10238 times
