Nowhere to install TMC2208 on A20T motherboard?
Blue_Collar
Post by Blue_Collar »
Fellow printers,
I was going to upgrade the three extruders with TMC2208 drivers, but there doesn’t seem to be anywhere to plug in the chips on the board. There seem to be 6 small soldered chips where I would expect the driver chips to go. I marked the chips with a red arrow and dots on the picture below, but I’m not sure the picture attached correctly. The A20T is very new (like a month old). Do the new boards not allow adding TMC2208 drivers? Any advice appreciated!
——————— last update 10-16-21
1). Geeetech i3 pro C with custom x axis, extruder carriage, Noctua fans, PIA magnetic build plate, 3d-touch, Marlin 2.x
2). Geeetech A20T with 3 in 1 out Geeetech extruder (diamond hot end failed), magnetic PIA build plate, dual gear extruder upgrades, Marlin 2.x
3+). Prusa Original MK3s x 2, Mini, MMU2s, Mosaic Palette 2s pro
—using PrusaSlicer, openSCAD
BreeOge
Re: Nowhere to install TMC2208 on A20T motherboard?
Post by BreeOge »
I was reading yesterday and I came across something that state the new Geeetech 4.1B is not changeable due to being soldered on the board. I came across it while looking to see if I could upgrade the Board to a 32 bit board.
Blue_Collar
That’s what I was afraid of. I would consider this a step backwards... probably saved about $0.10 per board.
Thank you for the info.
