Hi guys,
Could someone help me with setting X and Y axis to the right angle? I have been using my i3 Pro B for a long time and for majority of printed parts it seemed fine. However, recently I've noticed that X and Y axes are not set to exactly 90° to each other. There's small deviation of may be 0.5-1°
This results in the fact that for example a long box and a lid don't match each other if printed in different orientations (along X axis and along Y axis respectively). Also, because of that round objects are printed in elliptic shape. Visually it's impossible to recognize, it looks round, but when measured has deviation of ~1mm in diameter. That for example makes printing any gears impossible cause they won't work as part of one well tuned mechanism
The motor steps are tuned fine - narrow sticks printed along X and Y axes have exact length, so that tuning is not a problem. All symptoms say that X and Y axes are not aligned to 90° angle.https://mobdro.bio/ https://kodi.bio/
However I can't find where exactly I could assemble it incorrectly or which nuts/bolts are responsible for that.
So the main question is: How to tune angle between X and Y axes and what is the best way to measure it?
X-Y axes right angle adjustment?
BurnsCrack
Jump to
- Update Announcement/Product Release
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3/DIY Printer Series
- ↳ FAQ-Geeetech I3/DIY Printer series
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Configuration Profiles Sharing
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- ↳ Video about cleaning and replacing nozzles
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
