2 Colour Printing Issues - HELP!
Hi All,
Hope you can help, I have an A20M (1.1.8) which has ONE Hotend and TWO Extruders (E0 and E1) - for anyone unfamiliar with this printer.
Having real issues in getting the printer to interpret the GCODE two colour file - unless I'm being really thick, I get the following problem:
a] I find a 2 colour example stl file - it has 2 clearly defined colour segments with NO graduation between the two colours
b] I load these (2) files into Cura (with A20M profile already loaded in)
c] I then assign a colour to the respective segments and merged the print
d] This I then sliced
e] Saved as GCODE ready for print
f] (only did this in case I was going mad) I then open the GCODE file in text editor and search to make sure the "M163 E1 P1.00; Set Left to 100%
M163 E0 P0.00; Set Right to 0% M164 E1; Save Mix" commands don't say anything other than either 100% on or 100% off (so either E0 or E1 are exclusively in play at any specific time) - having checked the entire file, there is absolutely NO mention of anything else (so no 50/50 commands)
g] Save this fie onto SD card and pop into A20M SD card slot
h] Select the file for print and cross fingers
I] Printer switches randomly to 50/50 throughout print resulting in something that resembles a badly printed smudge. If I'm lucky, one colour might be 100%, but the second is a 50/50 mix....
Pretty new to this perhaps, but I'm totally perplexed as to what else to do - there must ether be something wrong with 1.1.8 firmware or a command that needs to be sent to say NO DON'T MIX THE COLOURS just please print it as a solid 100%, like the GCODE told you to...
Fatumpch
Fatumpch
- Screen showing the printer overriding the GCODE with 50/50 mix?
- IMG_4479.jpg (301.44 KiB) Viewed 18585 times
- Laughable 2 colour results so far...
- IMG_2344.jpg (622.2 KiB) Viewed 18585 times
Re: 2 Colour Printing Issues - HELP!
Hi, If you are referring to the need for monochrome printing,
the extruders used in each section need to be set in the setup.
If the color mixing ratio is 50/50, it is a fusion of two consumables.
gekame2993
Simple printing is easy, but when we talk about 2 color printing that time it is difficult. I need help for that guy who really know how can we easily do two color printing and how can it is be perfect for best essay writers online. I am waiting for you reply because i have no other choice.
Hi, may be related to the setting of cura,
Can you print using Repetier Host?
camilahenry
I have HP Color LaserJet Pro MFP M479fdw A4 printer, few days ago I noticed a green lines in my print and two days ago while printing my Halloween discount codes I noticed red lines instead of green and now it is only printing in green color I don't know what to do, anyone can help me?
If there are smears of ink on the back of your printouts, you can use an automated tool to resolve the issue.
Make sure the printer is loaded with plain white paper.
On the printer control panel, swipe the display to the left, and then touch Setup.
Touch Tools.
Swipe up on the display, and then touch Clean Page Smears.
The printer slowly feeds a blank page.
Wait for the printer to eject the blank page.
Try to print. If the print quality is unacceptable, continue to the next step to make sure you are using the appropriate paper for your print job.
Touch Tools.
couponduos
Our website promotes the best deal for our users. Feel free to go to the website for browsing the stores you like. Stores like https://www.couponduos.com/stores/anycubic-coupon-codes .
MarkaSigni123
- Contact:
Try these remedies if your printouts have improper colours: Make sure your printer software's Black/Grayscale or Grayscale settings aren't turned on. Check the nozzles on the print heads to see if any are clogged. Then, if necessary, clean the print head.
getscoupon
Gets Coupon (https://www.getscoupon.com/) is a global coupons and deals website. You can easily find most of brands' deals or promo codes. such as patpat coupon. You can also find review articles for many brands, such as BeddingInn reviews in 2022.
The problem you shared is very helpful to me, I have learned a lot from this article.
infected days
infected days
