Printer won't print without manual intervention
Linakesh
Post by Linakesh »
I have the strangest problem. My A10M won't actually print anything, sort of.
When I start a print, either from an SD card or OctoPi, the printer does an auto home, then a auto bed level (BLTouch), and waits for the bed and nozzle to heat as expected, BUT even after the selected temps are reached, it still says E1 heating.
https://snaptube.cam/
The control panel shows the correct temps, and OctoPi also shows the correct temps. In order to get it to actually print, I need to go to the cvontrol panel and change the default nozzle temp to something lower, and then it continues. It doesn't make any difference what I lower it to (only 1 degree is enough) nor does it make any difference what the temps are in the GCODE. I re-flashed the same code that I installed originally when I installed the BLTouch (a hex file I got from this forum, Marlin 1.1.9), with no difference. It does the same thing even if the printer isn't connected to OctoPi or not.
I have no idea where to go with this, and Marlin options are too complex to figure out. I only can use the Arduino IDE (no platform.io).
