How can we use PID Autotune on the A30T?
Is there a guide about using PID autotune for the Geeetech printers anywhere?
Re: How can we use PID Autotune on the A30T?
Sorry! We don't have this guide.MOCCOR wrote: Mon Oct 11, 2021 5:50 am Is there a guide about using PID autotune for the Geeetech printers anywhere?
Is there a way to do PID autotune on the hotend and bed? I know flashing other firmware it is possible. But this printers firmware does pretty much everything i've seen others do on Marlin. Maybe there is just a slightly different command than Marlin's for the PID Autotune?
Sorry, we wouldn't suggest others modify the printer, that will cause some responsibility issues.
But if you need the source code, please check the link: https://github.com/Geeetech3D/Prusa_I3_3Dprinter
If you need thermistor, maybe you can try to check on our website: https://www.geeetech.com/accessories-ho ... 6_108.html
