X-Y axes right angle adjustment???
JinstKebe
Post by JinstKebe »
Hi guys,
Could someone help me with setting X and Y axis to the right angle? I have been using my i3 Pro B for a long time and for majority of printed parts it seemed fine. However, recently I've noticed that X and Y axes are not set to exactly 90° to each other. There's small deviation of may be 0.5-1°
This results in the fact that for example a long box and a lid don't match each other if printed in different orientations (along X axis and along Y axis respectively). Also, because of that round objects are printed in elliptic shape. Visually it's impossible to recognize, it looks round, but when measured has deviation of ~1mm in diameter. That for example makes printing any gears impossible cause they won't work as part of one well tuned mechanism
192.168.0.1 router login 192.168.1.1
The motor steps are tuned fine - narrow sticks printed along X and Y axes have exact length, so that tuning is not a problem. All symptoms say that X and Y axes are not aligned to 90° angle
