Any 1 tried tl smoothers on the i3pro?
Does it help with artifacts for you?
Or is it generating more problems/ not changing a thing?
I can do some testing if no 1 tried yet
Tl smoothers?
Re: Tl smoothers?
Hi,using tl smoother can make the surface of the printed piece slightly smoother, looking forward to your test feedback.
Re: Tl smoothers?
Weep holes in foundation wall: My design no work properly not high z-axis
Re: Tl smoothers?
Oh I guess I never gave a proper report.
The smoothers did nothing of interest.
The new cura update on the other hand 4.12 for sure enhanced surface quality.
Re: Tl smoothers?
This article will go into detail about the magneto ignition system, its main parts, functions, benefits, and disadvantages with the application.
Re: Tl smoothers?
How Much Cost to Pump Septic Tank: Maintenance of the whole septic system is required for proper treatment and disposal of household sewage.
Re: Tl smoothers?
It Services Company Usa: Are you looking for the top IT companies in the USA to get your work done? From small-sized companies to MNC, about 80 percent of the companies are going for the outsourcing of IT services to the top IR services and solutions companies.
